[Solucionado] Minecraft no arranca con ATI radeon 3000
26/2/2014 12:10AM
Hola a todos.
Bueno el problema es el siguiente...
En casa hemos actualizado a windows 8 pro, hemos probado juegos, programas importantes y hasta ahi todo bien, hasta que se probó iniciar el minecraft dando como resultado este error:
Bad video card drivers!
Minecraft was unable to start because it failed to find an accelerated OpenGL mode.
This can usually be fixed by updating the video card drivers.
--- BEGIN ERROR REPORT 7fe0271 --------
Generated 25/02/14 22:58
-- System Details --
Details:
Minecraft Version: 1.5.2
Operating System: Windows 8 (x86) version 6.2
Java Version: 1.7.0_51, Oracle Corporation
Java VM Version: Java HotSpot(TM) Client VM (mixed mode), Oracle Corporation
Memory: 6519840 bytes (6 MB) / 26808320 bytes (25 MB) up to 518979584 bytes (494 MB)
JVM Flags: 2 total; -XX:HeapDumpPath=MojangTricksIntelDriversForPerformance_javaw.exe_minecraft.exe.heapdump -Xmx512M
AABB Pool Size: 0 (0 bytes; 0 MB) allocated, 0 (0 bytes; 0 MB) used
Suspicious classes: No suspicious classes found.
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
LWJGL: 2.9.0
OpenGL: ~~ERROR~~ RuntimeException: No OpenGL context found in the current thread.
Is Modded: Very likely; Jar signature invalidated
Type: Client (map_client.txt)
Texture Pack: Default
Profiler Position: N/A (disabled)
Vec3 Pool Size: ~~ERROR~~ NullPointerException: null[failed to get system properties (java.lang.RuntimeException: No OpenGL context found in the current thread.)]
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:244)
at org.lwjgl.opengl.Display.createWindow(Display.java:306)
at org.lwjgl.opengl.Display.create(Display.java:848)
at org.lwjgl.opengl.Display.create(Display.java:757)
at org.lwjgl.opengl.Display.create(Display.java:739)
at net.minecraft.client.Minecraft.a(SourceFile:235)
at avv.a(SourceFile:56)
at net.minecraft.client.Minecraft.run(SourceFile:507)
at java.lang.Thread.run(Unknown Source)
--- END ERROR REPORT 8b4674c ----------
Este error occure en este sistema:
Procesador: AMD Athlon(tm) II X2 270 Processor, 3415 MHz
Sistema operativo: Windows 8
GPU: ATI Radeon 3000 (Asi me figura en el administrador de dispositivos aunque he visto que AMD trata a la 3000 y la HD 3000 de la misma manera)
El juego funcionaba de forma moderada en cuanto a los FPS cuando tenia windows 7, pero funcionaba bien optimizando un poco la configuracion...
Ya intente actualizar java, poner versiones de java anteriores que vi que funcionaban bien
Ya intente actualizar los driver, intente poner una version anterior tambien
Y la verdad no recuerdo que mas, pero si me dieran una mano con este tema estaria muy agradecido.
Ah y casi lo olvido.
Este mismo problema esta en otra PC Lenovo (Pantalla y CPU asi como una mac).
2 core intel si mal no recuerdo
La GPU es una ati radeon HD 6315 (Asi figura en el administrador de dispositivos)
Bueno saludos y espero una ayuda, gracias ^^
26/2/2014 01:39AM
Lo que pasa es que el controlador no le puede estar dando la versión de open gl o que no la trae; a veces trae la 1.0 cuando deberia estar la 1.3.
Ponga esto en el navegador y lo descarga AMD_CodeXL_Win_1.3.4905.exe.
Busque la version del sistema operativo que ocupa esta en el final de la pagina.
fr21 26
26/2/2014 01:58AM
fr21 escribió:Lo que pasa es que el controlador no le puede estar dando la versión de open gl o que no la trae; a veces trae la 1.0 cuando deberia estar la 1.3.
Gracias por contestar!
Probaré con ello y le haré saber los resultados.
Saludos!
27/2/2014 08:46PM
Saludos!
He instalado el programa pero nada, me sale exactamente lo mismo.
Investigué un poco y el controlador dice entre parentesis "Microsoft WDDM v1.1" algo asi y encontre q ese tal WDDM de microsoft no admite o no contiene OpenGL. Sera posible encontrar un controlador para ATI Radeon 3000 y HD 6315 con OpenGL? Gracias.
28/2/2014 12:09AM
Busca una version más vieja del minecraft la 1.7.0 hasta la 1.5 o cambia de tarjeta de video o cambia las tarjetas de video si soportan. Porque si existiera un controlador no hecho por la catalyst es riesgo usarlo y quemar la tarjeta.[/b]
fr21 26
01/3/2014 02:59PM
fr21 escribió:Busca una version más vieja del minecraft la 1.7.0 hasta la 1.5 o cambia de tarjeta de video o cambia las tarjetas de video si soportan. Porque si existiera un controlador no hecho por la catalyst es riesgo usarlo y quemar la tarjeta.[/b]
El minecraft que trato de correr es el 1.5.2, en windows 7 funcionaba perfectamente, ya con windows 8 y habiendo instalado todo tipo de controladores no funciona y hasta intente con la instalacion automatica que ofrece la pagina de AMD, sin resultado.
Lo ideal seria que hubiera un instalador para OpenGL, de preferencia 2.0
O algo que le quite ese WDDM 1.1 al controlador ya que no admite opengl o no se, pero antes funcionaba...
Gracias por responder.
01/3/2014 09:21PM
Trate de reinstalar el windows si fuera falla de windows no pierde ningun dato solo abre el autorun y busque que el disco sea de la misma version de windows para que lo actualize le da en actualizar. Sí es que antes funcionaba yo no recomiendo instalar un driver que no sea de fabricante porque te puede dar errores.
fr21 26
08/3/2014 01:32PM
Encontre la causa del problema...
La causa es que el controlador de la tarjeta de video no fue actualizado para windows 8 y tiene un controlador modeado por microsoft (Es lo que pienso por el WDDM v1.1 que aparece al lado del nombre del controlador).
Es decir, tiene un controlador de microsoft q no admite OpenGL, instalé windows 7 ultimate 32 bits y no me dio ni el mas minimo problema, todo funciona perfecto y revise mas a fondo la pagina de AMD y no hay soporte para windows 8 para el controlador de esta placa. En conclusion, buscaba un controlador que no existia xD
No pienso bajar un controlador modeado, aver si me quema la placa jeje
Y bueno tendré ambos sistemas entonces, gracias por tomarse el tiempo de responder!
Saludos!!
